43 B too fast in 1st Gear
oak
07-25-2005 12:31:35
Need to reduce gearing in my 43 JD B. Can gears be Changed to Slow it down? It has Hi Low aready. I was told that Parts out of another year may help? Thanks for your help.
DickD
07-26-2005 05:24:39
 Re: 43 B too fast in 1st Gear in reply to oak, 07-25-2005 12:31:35
Hello I don't think the ground speed in any B is slower than yours, except the late models, which have 6 individual gears,and I am reasonably sure these won't interchange. You didn't say what size tires you have on your B. They came out with 9 inch tires, and if it now has 10 or 11 inch, changing them will slow it down. Also if you are lucky enough to find a set 0f 36 inch rims, this too will work. Hope this helps. DickD
Oak
07-26-2005 05:44:38
 Re: 43 B too fast in 1st Gear in reply to DickD, 07-26-2005 05:24:39
Thanks For your Information. I have done a little Reading here and There have been Mentions of Late Model Bs Having a Creeper Gear I think after 1947 or so I would Like to Change Gearing if It can be done. I am Pulling this Tractor and If I can not slow her down Ill have to let her set. Its no good on the Trac. Thanks Oak
jd b puller
07-29-2005 18:23:56
 Re: 43 B too fast in 1st Gear in reply to Oak, 07-26-2005 05:44:38
what are you running for an engine and what do the rules allow?
