1941 JD B - Surges when running - help please
Neal (In)
07-25-2005 10:56:45
I just got my 41 B back together and took it to it's first show. When I got there I noticed that it was not running smooth. It acted like it was surging. One of the guys at the show said it is probably in the govenor.
Now, can someone talk me through the govenor adjustments?
I forgot to mention that it has a rebuilt carb on it and we tried this first with no luck at solving the problem.
P Browning
07-25-2005 13:28:25
 Re: 1941 JD B - Surges when running - help please in reply to Neal (In) , 07-25-2005 10:56:45
Yours is a classic case of some blockage remaining in the IDLE pathways of your carb -- the IDLE path involves no less than having to make SIX drilling operations. Run the test below to make sure your carb is indeed not the culprit! Let us know, and then we take the next step -- PatB
37. Testing -- LOAD & IDLE Pathways You can test your carb's IDLE & LOAD pathways by manipulating the IDLE & LOAD needles. Here is how it goes: (1) CAUTION: This test involves radical adjustment of both the LOAD & IDLE needles. Before starting the engine, observe the position of each needle lever, and count the number of turns OUT that each of the two needles is at so that you can put them back where they were before this test is run. (2) With the tractor running at least at half-full engine speed, turn the LOAD needle all the way in. The engine will continue to run if the IDLE SYSTEM is open, and if it stops running, -- the idle system IS NOT open! Assuming this test is a pass, reset the LOAD needle where is was and go on to test two below. (3) With the engine running at least at half-full engine speed, turn the IDLE needle all the way in. The engine will continue to run provided the LOAD FUEL system is open, however, in this mode, engine operation will be a throttling pattern. As engine speed drops, the governor will open the throttle to draw LOAD FUEL because the idle path is closed. This pattern, however, indicates the LOAD FUEL channel is open & working as it should. If the engine stops running, the LOAD FUEL channel is blocked.
Neal (In)
07-26-2005 05:16:05
 Re: 1941 JD B - Surges when running - help please in reply to P Browning, 07-25-2005 13:28:25
Ok, I guess I should have said first that this is a NOS carb (DLTX 34) that was professionally checked out before I bought it. The people I bought this off of rebuild these for a living.
Next, I have tried the carb adjustment route and have had no luck. You can adjust either one of needles with no affect on the way the tractor runs.
I also readjusted the throttle shaft that goes to the carb. I set it exactly like was mentioned in the other post and like the manual said. With the carb and rod set as mentioned it was 1/2 a hole away from going together.
Now,whats next????
Thanks for all the help. Just wanting to get the darn thing running properly.
Mike M
07-26-2005 06:35:02
 Re: 1941 JD B - Surges when running - help please in reply to Neal (In) , 07-26-2005 05:16:05
I would DO the test Pat recommended reguardless of who or where the carb. came from.
Pappy
07-25-2005 11:45:08
There are many things than can cause this other than the governor. Here are just some simple suggestions based on my experience.
1. Adjust the carburetor idle and load needles--
2. Adjust the screw on top of the carburetor that rests against the vertical spring for low idle control--
3. Adjust the length of the throttle rod. Remove the throttle rod from the carb and push the throttle lever wide open. Now, hold the carburetor throttle in the wide-open position. The rod should be about one half hole width short to fit in the carburetor. 4. Dopuble check the fuel flow from the tank--be sure plenty is flowing through the carb. 5. You might need to check the float level in the carb--
These are the simple things to check first that won't require a large cash outlay. I'm in favor of this when possible.
48Bboy
07-26-2005 07:50:39
 Re: 1941 JD B - Surges when running - help please in reply to Pappy, 07-25-2005 11:45:08
My tractor has the same problem. I put the same post up back on the 13th. I contacted Roberts Carb at www.robertscarbrepair.com. They sell the drill bits to open up the idle passage ways. I would give them a call to get their opinion. If adjusting the screws aren't changing the way your tractor runs those passages must be blocked. Good luck.
