JD MC Track adjuster
Doug Spalding
10-24-1999 04:22:46
The threads on the stub axle are shot. Any thoughts on how I can repair. I am unable to locate a new adjuster. It is the outside left adjuster. Can I weld the axle in place or will that cause me a problem? Thanks in advance for any suggestions.
Kelly C.
10-24-1999 14:16:22
 Re: JD MC Track adjuster in reply to Doug Spalding, 10-24-1999 04:22:46
Hey Doug,
Check to see if the female threads are alright in the front idler bracket by turning the axle around and trying to screw it in. If they are ok, simply get a new axle/pin made at a machine shop as it is a very easy part to turn. Even if the idler bracket threads are bad I would never weld the axle pin in there. Once you ruin these old parts another small piece of history is gone. Any machine shop could drill it out and press fit an insert in there.
Doug Splading
10-24-1999 15:34:26
 Re: Re: JD MC Track adjuster in reply to Kelly C., 10-24-1999 14:16:22
Hadn't thought of a shop being able to do anything for those threads. The axle seems fine. The threads in the bracket are stripped. I will take it to a shop and see if they can press some threads in for me.
Thanks.
RonMC
10-27-1999 21:05:24
 Re: Re: Re: JD MC Track adjuster in reply to Doug Splading, 10-24-1999 15:34:26
Where are you located ? I have a couple of usable leftover brackets, or can get good ones locally. If you're interested, reply to my e-mail. I'm in British Columbia, Canada
Doug Spalding
10-28-1999 08:06:07
 Re: Re: Re: Re: JD MC Track adjuster in reply to RonMC, 10-27-1999 21:05:24
Ron. I could use 2 of the left side brackets. One has been broken out on front and welded, the other, the threads stripped. Any idea how much you would need to get for them, and how much to ship. I'm definetly interested. Couldn't get your e-mail link from the posting. I am at [email protected]
Thanks
Doug Spalding
10-28-1999 11:45:23
 Re: Re: Re: Re: Re: JD MC Track adjuster in reply to Doug Spalding, 10-28-1999 08:06:07
By the way, Ron, I am in Maine-Northeast USA.
the part umber is TE231Y
Thanks again,
Doug
