New owner of 3020D and Questions???
Bill Tremel
07-25-2005 04:58:46
I just purchased a 3020D. I always wanted a 3020D. It's a 67 year and has dual remotes, WF, Syncro, Roll-bar (no canopy) and trac-lock. The tractor has 5200 hours on it and is in very good original condition. (I wanted a later model with side consol, but I can't be too pickey.)
I need to haul this tractor and was wondering what the weight is? Both rears are filled with calcium. The Tractor also has 6 OEM front weights and two per each rear wheel.
Also, anything I need to look out for? I took the tractor out for a spin before I bought it. It shifts well in all gears. The previous owner kept very good maintainence records. The tractor does smoke a little under a heavy load. There is also a small amount of oil resedue toward the top, front of the engine. It doesn't appear to be the head gasket, but maybe a small leak in the fuel line.
I gave $6000 for the tractor. Was this a good deal? I have been looking for awhile and most of these tractors are Whipped for this price. The only cosmetics would be that the battery box's have been removed and a home made one was installed. Also, the side emblems have been replaced with a modern JD decal. There are NO other digs or rust spots in the sheet metal.
Thoughts and ideas are welcome. Thanks...
(Now I can retire my 720 from farm labor) :-)
buickanddeere
07-25-2005 18:02:20
 Re: New owner of 3020D and Questions??? in reply to Bill Tremel, 07-25-2005 04:58:46
Get rid of the calcium before hauling. The tractor is too heavy for it's HP with just the cast weights. Less chance of rust problems in the future too. There are several posts on here about Zenieth carbs and other tuning tricks. Done right, they are not gas hogs.
Mike M
07-25-2005 18:36:09
 Re: New owner of 3020D and Questions??? in reply to buickanddeere, 07-25-2005 18:02:20
I doubt that a 3020D as stated will run very long or hog much gas ??
buickanddeere
07-25-2005 22:23:53
 Re: New owner of 3020D and Questions??? in reply to Mike M, 07-25-2005 18:36:09
Darn. Wonder what made me think that 3020 was a gasser. I have seen a 3.5HP Briggs lawnmower run on winter diesel. And a Detroit run on gasoline.
Bill Tremel
07-26-2005 12:03:49
 Re: New owner of 3020D and Questions??? in reply to buickanddeere, 07-25-2005 22:23:53
Thanks for the input. I have only a 10K GVW trailer, so I'm going to have to find someone to haul this tractor for me.
My 720 is gas and it is not for sale. I need to rebuild the engine. The tractor is in good shape, but the bore is so worn, it's egg shaped. My plan is to rebuild and paint it. We'll still use it on the farm for some chores, but I plan on putting the new (old) 3020 on the plows, bailer and mower conditioner.
Thanks again.
Mike M
07-26-2005 05:26:56
I hope you know I didn't want to pick on you,but some of this stuff gets confusing enough. I have caught myself (luckily before someone reamed me)misreading or misunderstanding what was written.
buickanddeere
07-25-2005 18:02:10
JDBert
07-25-2005 10:39:35
I'd say your probably pretty close to 10,000/lbs for weight. 7320 + 570 (front weights) + 600 (rear weights) + 1800 (fluid). Front weights 70/apiece and the mounts weigh about 75/side, rear weights are 150/apiece, I figured 75 gallons/calcium at about 12/lbs/gallon. I'd say you did ok on the price, I also agree with mike about the 720 pulling better though.
David from Kansas
07-25-2005 08:07:49
Those are good little tractors. Don't worry about a little black smoke under load, it is normal. That oil seepage could be your valve cover gasket. Not a big problem unless it gets to leaking excessively. I think you will enjoy your 3020. Good luck.
MN Bob
07-25-2005 06:07:34
If the JD 720 is Deisel and wide front do you have it for sale? If so email or post here as response. Oh yes, the 3020 shippped at 7320 lbs. Calcium weighs more than water so over 8 lbs per gal. and 18-4-34 (yours are probalby 15.5-38?) tire holds about 100 gallons at 75%. Rear weights are probably 100 lbs each and no idea on the front.
Mike M
07-25-2005 07:35:49
 Re: New owner of 3020D and Questions??? in reply to MN Bob, 07-25-2005 06:07:34
He still may need it for the heavy grunt work. Those newer ones make more HP but just can't pull like the old ones.
