Fan Shaft
Pete/ME
07-25-2005 02:49:22
Figured out the easiest way to remove the block was to take off the fan shaft and gov. assembly in one piece. Looked at the block and it looks O.K. still can't figure out how anti-freeze got into the crankcase. (B-215xxx)
Maark
07-25-2005 11:45:28
 Re: Fan Shaft in reply to Pete/ME, 07-25-2005 02:49:22
Check the pushrod tubes in the cylinder head for your antifreeze leak.
Mike M
07-25-2005 04:21:47
No substitute for the book. I finally got a look in my book. That block is made to come out without removing the fan shaft. Working from the RH side slide the block forward and turn it so the RH side is up in the air,then work the bottom down and the studs straight up in the air while sliding it ahead,and turn the water pipe connection surface uppermost and go out the RH side with the studs facing you. The gen.and bracket must also be removed first to clear. Oh well while you have the gov. and fan apart may as well rebuild them I"m sure they need some attention after all these years.
