60 thermostat re-post to the top- wheres the therm
jd60
07-24-2005 15:24:24
jd60 thermostat wheres the thermostat?
F-I-T
07-24-2005 18:33:36
 Re: 60 thermostat re-post to the top- wheres the t in reply to jd60, 07-24-2005 15:24:24
Well, that depends on the serial number. Early versions (up to 6030936) had a thermostat link that controlled the front mounted radiator shutters. From 6026000-6030926, they added a conventional coolant flow restricting automotive thermostat in the upper water pipe from the head to the top of the radiator. Then they changed to a different pipe mounted unit at 6030927-6054499. After 6054500 they went to yet another type with a by-pass line, once again in the upper radiator pipe. So you'll need your serial number and a parts book to get the correct unit.
Frank
SM in Wi
07-24-2005 17:48:44
At the bottom of the radiator. Its not like most that stop the flow of coolant. The thermostat on a 60 and some other John Deere tractors works the radiator shutter.
Ben.So.Tex
07-24-2005 17:39:36
Should be where the top water pipe enters the cast elbow near the block. thats is where it is on my 720s and 730, hope thats helps. I have a 60 but it does not have one, guess it has been removed before I got it. Runs good for me. Good Luck Ben
jd60
07-24-2005 19:56:38
 Re: 60 thermostat re-post to the top- wheres the t in reply to Ben.So.Tex, 07-24-2005 17:39:36
I checked there but had a hard time looking in there, so I poured some water in there thinking if it is stuck it would over flow but it didn't.
Don't have a book.
