2030 BRAKE PROBLEM!!!!!!!
Ponchobro
07-24-2005 12:03:31
Hello, I lost the left brake on my 2030. When I tried to bleed it I got a little pedal back but lost it again. Any idea's?? Thanks for your input!!!
Roy Suomi
07-24-2005 20:21:50
 Re: 2030 BRAKE PROBLEM!!!!!!! in reply to Ponchobro, 07-24-2005 12:03:31
Get a set of JIC plugs that fit the brake lines at the final drives. With light pressure bleed out the line at plugs. With plugs tight in lines see ifyou have a good pedal . If you do then I would remove a final drive to check brake piston and sealing rings for damage or worn condition..If you still can't get a good pedal with the plugs in the lines then you will have to check for a problem in the brake valve..Something is bypassing internally. The only fix is to disassemble and look for problem..If you need to fill the brake valve there is a plug on the top , remove it , fill it with hydraulic oil...
