A,B,G wheel weights
Daniel Chestnut
07-24-2005 09:31:08
I"m trying to put on two sets of wheel weights on my G. I believe the part number of them are D2628 or something close to it. Is there somekind of a starter weight that I need to find? I put the first set on and they fit just fine. When I go to put the second set on, the back side of the second set don"t want to slip on the 3/4 in lip of the first weight. Thanks in advance.
RalphinWI
07-24-2005 11:08:28
 Re: A,B,G wheel weights in reply to Daniel Chestnut, 07-24-2005 09:31:08
If I can read mine they are D2628R. There is a stack of 6 at the farm, so I am pretty sure they fit together. Are you sure the interference is not coming from the bolt or the position of the bolt? It has been 50 years since I have installed a set, but one must use a recess in the weight for the bolt head. I don't recall is this recess also provides clearance for the nut on the previous weight or if the bolt pattern alternates. Look and think before you lift. I added a couple of sets of the later weight to a 4240 a couple of years ago. I admit I lifted before I looked and thought - installed the first one three times.
