Choke problems with JD 730 Gas
charlie
10-25-2003 16:22:38
I can not get my 730 to start using the choke. The carb throats are wet with gas but it just does not seem to draw gas into the cylinders.. The only way I can get it started is to use the choke a few times to get gas into the carburator throat, and then as soon as I close the throttle plate completely, the engine seems to draw gas and fire .
I looked at the choke and it opens and closes freely. One thing I noticed is that the choke plates are spring tensioned , so that when they are closed, you can put your finger in the throat and push against the the plate and it will open. But as soon as you stop, it will close aqain because of the spring tension.
I was wondering if the vacumn of the cylinders could cause the choke plates to open because of the spring tension and therefore drawing more air than gas.? Is there suppose to be spring tension on those plates?
Clooney
10-26-2003 14:58:53
 Re: Choke problems with JD 730 Gas in reply to charlie, 10-25-2003 16:22:38
Charlie, your problem could be any number things.
~You are correct on that choke, it does have a spring loaded choke plate in it that allows some air to by-pass it after the engine starts. That spring shouldn't be so weak that cranking opens it very far. As a test, try pulling the air intake elbow & placing your hand over the carb intake during cranking. If it starts better you either have a weak spring or not enough wind up on that spring.
~Some of those old 2-cylinder Deere's do start better with little or no throttle opening during cranking so if it starts better at no throttle that could be normal.
~The other thing you could be fighting is a broken or disconnected starting by-pass wire or open by-pass circuit. On that 730 there is a wire that by-passes the ballast resistor during cranking to allow full battery voltage to the ignition coil during cranking. If that circuit isn't working it won't make much of a spark during cranking & that means almost a perfect fuel mixture is required during cranking to get it to start...To verify that circuit is functioning put a voltmeter on the ign switch side of the coil during cranking & see if the coil voltage is above 8-9 volts, if so your by-pass is working. If below 6 volts you probably have an open by-pass circuit.....
~You could also have a worn carb throttle shaft or throttle shaft bushing that allows air to by-pass the choke during cranking & that won't allow the carb to meter much if any fuel into the starting air stream [somewhat common of a high hour tractor]..Grab the throttle shaft & see if there is excess play in the shaft to carb bushings..
~Excessively worn intake valve guides can also effect the cranking vacuum & allow air to enter the intake at that point instead of through the carb/choke.....
~About all that's left is a poor compression during cranking due to engine wear or excess side clearance in the rings to piston grooves. [do a cold compression test to see where you stand in that area]...
[email protected]
ChuckW
10-25-2003 17:58:53
the spring loading on the butterfly is as designed...it's supposed to pull off with vacumn when tractor fires to prevent flowing. You need to start tractor with throttle in the near closed position. You may also have an ignition problem, electronic ignition would greatly improve your starting and running.
