620 Hydraulics
Salty
07-24-2005 05:46:37
Is the hydraulic system on a 620 an open or closed center system? Also, does anyone have any wisdom re routing the discharge side of the hydraulic pump through a 2 spool valve for a loader with a power beyond capability before it goes to the rear hyraulic control? Would I need to install an additional reservoir in the system? I bought a 50 loader that has a hydraulic bucket that I want to mount on the 620.
Mike M
07-25-2005 07:45:56
 Re: 620 Hydraulics in reply to Salty, 07-24-2005 05:46:37
You could always hook in the outlets on the back and run to the new valve, you just need to tie the lever on the tractor one way or the other.
mike brown
07-24-2005 06:36:01
Those old tractors had gear pumps. Gear pumps need to be able to pump oil at all times, either to a cylinder or in a loop back to the reservoir so must have open center valves. Closed center valves are used with variable displacement pumps, such as vane pumps.
Any re routing of out put lines will have to take into account the constant out put of the gear pump.
To illustrated what happens, start your tractor and with nothing hooked up to the hydraulic outlets move the valve forward or back. There is a relief valve in the powerrol to protect the system but it will yell in protest.
