Could it be the switch?
ashfarm
07-23-2005 01:43:58
Lights work fine when I ran a hot wire directly from the battery to the light. And also when I touched the light wire directly to the power "in" on the switch. But when wired correctly to the switch it throws the breaker as soon as you turn the switch on.
Randy in OH
07-23-2005 05:17:54
 Re: Could it be the switch? in reply to ashfarm, 07-23-2005 01:43:58
It could be the switch since by your last post it sounds like you overload a breaker by using the light switch properly, but not by bypassing the switch and shorting the light feed wire to the incoming power wire on the switch. Pull all wires off of the switch (after you've labeled them of course) and check continuity with an ohms meter from the terminal that used to be the power feed to the switch to ground. Select all positions of the switch to see if any setting gives you a current path from the power feed terminal to ground. If so, the switch is bad.
