JD L ???
doral
10-24-1999 00:35:44
how many different types of model L were made,, and how do you tell the difference
Steve
10-24-1999 01:00:44
 Re: JD L ??? in reply to doral, 10-24-1999 00:35:44
6 if you count Y's and 62's which were predecessors of the L's. L's were available first in unstyled version(square engine cover and screen over radiator), then went styled(hood rounded at back, louvered front) later. There was a styled LI(industrial) painted yellow, and the LA, styled with a larger engine.
Steve
10-24-1999 01:08:46
 Re: Re: JD L ??? in reply to Steve , 10-24-1999 01:00:44
Also, forgot about serial numbers. 621,000 to 621,078 was a 62 and very rare. 621,079 to 622,563 were unstyled L's. 625,000 to 634,840 were styled L's from 1938-1941. 640,000 to 642,038 were styled L's from 1941-1946. 1938 to 1941 LI's were numbered with the green ones. After 1941, LI's got their own numbers, 50,001 to 52,019. LA's from 1940 to 1946 were numbered 1,001 to 13,475.
Terry
10-25-1999 18:29:13
 Re: Re: Re: JD L ??? in reply to Steve, 10-24-1999 01:08:46
If you will check your serial no. plates you will find that the industrial version is marked IL
