2210 tractor
mike pritchard
07-22-2005 18:52:02
how good is the 2210 tractor. I am looking for something for construction clean up. plus a little bush hogging. Will it do, or do i need to go to the 90 series.
John Deere DLR
07-23-2005 23:24:21
 Re: 2210 tractor in reply to mike pritchard, 07-22-2005 18:52:02
Depends on how you want to work the tractor....I sell the 2210 w/ Loader for about 13, Its nice but you will only do so much 4' box, 4-5 foot rotary, 4' tiller, no backhoe capable, limited lift capacity aprox 500lb to full hieght, so depending on how extensive site cleanup may be on your construction jobs this may not be the correct choice.
Now the 90 series such as 790 is nice more power 27 @ the motor and you can run 5' implements and with a 300 loader you lift capacity to full hieght goes to aprox 800lbs. This tractor w/ loader you can expect to get in the 16's. This tractor will also run a backhoe with 7' dig depth. With the 790 however keep in mind it is a gear driven tractor unlike the 2210 being a hydrostatic (automatic). With the 790 trans you need to stop to shift from gear to gear so for you site clean up there will be more time involved with repetitive forward back loading and unloading materials.
The 4010 series is a great series. You can stay in the mid frame 29 to 37 hp tractor still run 5 to 6 foot implements and backhoe options of 7 or 8 foot dig depths. This tractor has 2 loader options a 300X with 1300lb lift cap. to full hieght or a 300CX with I believe 1600lb lift cap. The 4010 series right now is being replaced by the 3020 (mid frame) and 4020 (large frame) series of tractors. There are still dealers out there with stock of 4010 tractors and JD is putting good incentives towards these tractors to make way for the new series. If you find a dealer with em take a good look at the 4310 Power Reverser Tractor 4x4. This will give you 32HP and a 12 forward 12 reverse trans with a forward-reverse shuttle lever on the dash. Whith this trans you can shift as you would in a stick shift car as you are rolling and for repetive forward reverse operation (site clean up) the shuttle lever is clutchless and the quickest alternative. This tractor will go for 18's to 20's depending on loader dealer and incentives.
Take a look at the 3020 series while you are there. Basically they are the same, short of body modifications, operator platform, HP ranges from 29.5 to 44 with the top two being turbos. These are available with Hydro or Power Rev. trans as are all the 4010 series.
As far as looking any larger that really depends on what else you want to do or how big of a property do you own that you want to work, I am assuming that you are not working a large piece being that you started by looking at the sub compact. If you are working a larger piece of property def. look at the large frame and 5103 and 5025 series of tractors.
buickanddeere
07-23-2005 10:37:31
Price the 5105 while you have the salesperson's attention. For about the same $$$, 50HP in a utility tractor beats an oversized garden tractor.
tsmith1499
07-22-2005 19:27:37
Keep going up. The 2210 is to small for anything except homeowner related chores around the house. 4000 series is the way to go. Tom
