Bleeding an R
Big_Roy
07-22-2005 07:43:17
Managed to run my R out of fuel last night. Since I haven't changed the fuel filters, I decided now is as good a time as ever! I've got the manuals so I know kinda what I'm facing. What I'm wondering though is, will I have to take the pump and valve covers of and bleed the lines at the pumps and injectors?
Mike M
07-22-2005 08:54:10
 Re: Bleeding an R in reply to Big_Roy, 07-22-2005 07:43:17
I have had good luck starting 2 cyl. diesels with just bleeding at the bleed screws. I would save bleeding at the injectors as a very last resort.Just too much stuff to tear off.
Big_Roy
07-22-2005 15:21:46
 Re: Bleeding an R in reply to Mike M, 07-22-2005 08:54:10
Just my luck! I even tried belting her up to my A for about 30 minutes...no dice. I ended up having to take the lines from the pumps to the injectors loose. Guess I'll be a little better at checking the fuel take from now on!
No Fuel
07-22-2005 18:30:46
 Re: Bleeding an R in reply to Big_Roy, 07-22-2005 15:21:46
Been there-done that and it sucks!!!!! !
Two hours running the pony to get it right. Seems to even run better after running it out of fuel than it did before---?
