4230: how warm is too warm?
R. John Johnson
07-22-2005 07:22:43
Hi everyone.
Been baling up the hay like crazy. Really like the 4230, but I think I have a problem. After the tractor runs for an couple of hours or so I start to notice what sounds like a hydraulic chatter in the cab. After 4 or 5 hours the hydraulics on the tailgate are occasionally a little jerky when closing the baler tailgate. I put my hand on the rear end and hydraulic couplers and I couldn't hold it there for more than 3 seconds. Listened in the hydraulic fill tube and could hear oil spraying. The 3 point was in the raised position, so I lowered it(the arms are off so no potential damage to PTO). The spraying noise was much reduced or gone. Ran the tractor another day and the temp still went up, but I could hold my hand on it without taking it off, but just barely. I'm sure I have a high pressure leak, but my normal repair place is not an option, and I have no way of lifting the cab off myself. How safe is it to run the tracor like this? If I keep going will I cook the rear end? Tame hay is almost done, and then I will start our native hay, which will allow me to run the tractor intermittantly (the rake can't keep up to the baler). Would running the tractor an hour on and an hour off be safe? Any input would be appreciated.
John
txgrn
07-24-2005 19:06:53
 Re: 4230: how warm is too warm? in reply to R. John Johnson, 07-22-2005 07:22:43
Funny, as I was baling today, I noticed funny noises when I initially started to raise the gate. Didn't pay much attention to it but I did hear a noise. The gate responded as directed.
On heat; that tractor uses a different oil cooler than it's predecessors. Instead of a radiator in front of the engine coolant radiator, it uses what looks like a tube heat exchanger; like a big boiler would use but smaller and on the left side in the middle of the block.
Since the oil is cooled, it says that JD knew it is going to get hot, especially after you run for awhile. Since engine coolant is apparently what is used for cooling, I'd expect it to get hot (actually hotter) as the engine coolant gets hot.
So 140 degrees is hot for hot water and thermostats take coolant up to 180-200 so I'd expect it to get hot and you couldn't hold your hand on parts containing it.
I have valves that vibrate sometimes under certain conditions....other tractors. They make a houling noise. You can move the lever and change the sound and sometimes it comes and goes. May be trapped air in a newly connected implement looking for a way out. I don't worry about it.....could be some turbulence, or oscillating.
Maybe I need to start worrying about the noises mine makes..... naw wrong thing to do....I don't want any problems.
HTH
Mark
RJ-AZ
07-23-2005 17:07:40
You can remove just the rockshaft valve which has one SCV attatched to it without having to take off the complete rocksaft housing. There is a little transfer pipe at the top front area that is O" ringed on both ends tha feeds the rockshaft cylinder. There is also a woppyjawed load control linkeage involved that can cause problems going back together. Sounds like your problem is in either the rockshaft valve or the one SCV (selective control valve). This is where a good shop manual comes in handy. Lots of Luck!
R. John Johnson
07-23-2005 08:22:15
More information. Tractor is new to me this spring. I have never chaged the hydraulic oil filter. Oil cooler and side screens are clean. 3 point arms seem to raise and lower at a normal speed, but I did notice the control effort on the 3 point lever is higer than I would have thought. Effort on the control is less when the motor is shutoff.
John
Tx Jim
07-23-2005 04:33:42
 rockshaft removal in reply to R. John Johnson, 07-22-2005 07:22:43
John,the rockshaft can be removed without removing S-gard body but first you should check the settings of the rockshaft valves.There are several things on a JD that can cause heating of oil(steering,hi-lo,scv's and rockshaft). How quickly does 3pt lower after engine is stopped? Is oil cooler and radiator clean of trash? Tx Jim
txgrn
07-24-2005 19:12:09
 Re: rockshaft removal in reply to Tx Jim, 07-23-2005 04:33:42
Ok Jim, what about the 3pt rate of drop. Are you saying that if it falls like in an hour you have a rock shaft problem?
Besides, what is a rockshaft anyway?
Thanks,
Mark
txgrn
07-25-2005 05:49:45
 Re: rockshaft removal in reply to txgrn, 07-24-2005 19:12:09
I found out what a rockshaft is. Interesting name.
Mark
Dieselrider
07-23-2005 04:10:51
When is the last time you changed the hyd. oil and filters? Could it be the filters plugging up and starving the pump? If that is the case you don't want to run it.
onefarmer
07-22-2005 10:54:34
Sounds like my 2550. Ok till it gets warmed up then the loss of Hyd pressure when the engine is slow. And the chatter as the main pump tries to catch/keep up. Been that way for 5yrs+. Doesn't seem to be roasting the oil but gets so hot I cant touch the rearend. I think an o-ring blew where the lift cover attachs.
