? For model 60
scott(nc)
07-21-2005 09:40:31
hello to all Iam new to the JD fourm. i just got a JD model 60 tractor so i can start to restore it. I left the fuel on the other night and all the gas leaked out in to the motor.(12gal) Two question i have are will it hurt the motor and where is the drain and fill for the motor oil? i have not got my service maunal for the tractor yet. thank and any answer will help.
Dick Dillman
07-26-2005 12:21:40
 Re: ? For model 60 in reply to scott(nc), 07-21-2005 09:40:31
Hello Scott; Welcome to the new experience of much grease under your fingernails. I noticed you evidently have a manual shutoff on your fuel. Something that may be filling your crankcase with fuel is a deal that came out on these tractors to shut the fuel off automatically if the oil pressure dropped
They had a diaphram in this device that sometimes would rupture, filling the crankcase with fuel. Might be a good idea to check and see if this is still installed on your tractor. Hope this helps you. DickD
Dennis Andres
07-21-2005 20:14:35
After removing the spark plugs there are two hex head pipe plugs under the cylinders about 3 inches from the head. This is where the compression release petcocks can be installed.If you remove them and slowly turn the engine by hand this should help drain your cylinders.I would use a 6 point socket to remove the plugs to avoid rounding them off.You can install petcocks if you like after draining or just put the old plugs back. Hope this helps
Kris A NC
07-21-2005 09:50:57
Scott where in NC are you located? I am in Charlotte. Welcome to the JD world. The gas will wash the oil off of the cylinder walls and make it a little harder to start. I would say take the plugs out and put a hose on a turkey baster and get the fuel out that way. To drain the crank case there is a pipe plug on the bottom front of the main case. I would suggest using a 5 gallon bucket. It comes out awfully fast and there is 7 quarts of oil or so. Good luck!
Kris A NC
scott(nc)
07-21-2005 10:14:16
 Re: ? For model 60 in reply to Kris A NC, 07-21-2005 09:50:57
kris I live in Concord just off hwy 601. My house is about 2.5 miles for hwy 49 and 601 intersection.
Kris A NC
07-21-2005 12:35:25
 Re: ? For model 60 in reply to scott(nc), 07-21-2005 10:14:16
Was this 60 sitting up on highway 29? I saw one there about a week ago. Just curious. Are you in a tractor club?
scott(nc)
07-21-2005 14:25:44
 Re: ? For model 60 in reply to Kris A NC, 07-21-2005 12:35:25
yes it was sitting there. it runs fine and no iam not in ant clubs yet. let me know of some if you can.
old
07-21-2005 09:50:29
It will only hurt the engine if you start it. Under the engine you should find 2 or 3 drain plugs the one closes to the rad will be for the engine oil. Sorry can't help much more since I don't have a good run 60 just one for parts.
scott(nc)
07-21-2005 10:15:20
 Re: ? For model 60 in reply to old, 07-21-2005 09:50:29
what kind of parts do you still have for the 60?
old
07-21-2005 11:23:48
 Re: ? For model 60 in reply to scott(nc), 07-21-2005 10:15:20
Most all of it but the sheey metal
Island A
07-21-2005 11:34:08
 Re: ? For model 60 in reply to old, 07-21-2005 11:23:48
Got a manifold and carb (gas) you wanna sell? Dave
old
07-21-2005 11:37:36
 Re: ? For model 60 in reply to Island A, 07-21-2005 11:34:08
Still have the manifold but not the carb. Drop me an e-mail
