Had some minor coolant leakage in one of the larger gaskets that connects the block to the heat riser tube that goes to the radiator in an old D. Decided that it might be worth while to try a can of Bar's Leaks instead of tearing the whole thing down. After predisolving the Bar's Leak pellets in hot water and adding it to the already hot radiator system, I noticed that the fluid flow within the radiator, while running, was not that much. Additionally, the coolant at the very top of the radiator did not really move at all. A little coolant could be removed, and then all of the fluid would begin moving, but when refilled, there was always a small area within the upper reservoir, above the baffle, that was stagnant while running. No problem as far as cooling the engine, but it did present a problem with evenly distributing the Bar's Leak particles and protective film. The film would tend to collect at the top.After talking to the Bar's Leak factory, I found out that temperature does not play a role in the effectiveness of the Bar's Leak. The reason for running the vehicle after adding their product is simply to provide movement of the coolant which enables uniform coverage within the system. The more movement, the better. Harbor Freight, this week, happens to have a 1" clearwater pump on sale for $23. I connected the engine drain to the inlet of the pump, and ran a 1/2" hose to route the discharge to the radiator. Found out that if you leave an air gap between the top of the fluid and the pipe discharge, that there is better mixing action of the Bar's Leak additives. Left the pump on overnight, and as of now, perhaps 95% of the leakage has stopped at the gasket. Note that only one can of stop leak was added, and the directions say to use 1 can for up to 4 gallons of coolant. Will add another can if the leak is not stopped by tonight. Thought I'd pass the factory information on, and let anybody that is interested know that an appropriate pump is on sale right now. Greg
