JD 2355 troubleshooting - synch. transmission
Aefallon
07-21-2005 06:47:36
changed hydraulic and transmission oil in my 2355 John Deere tractor. Bled the brakes. JD Manual very sloppy about details. I had to figure them out. Tractor is working with renewed strength but the problem that caused me to change the oils still remains. The tractor sometimes when I reverse and then move forward to make a sharp turn stops and it takes a minute or so before the wheels start turning again. It has happened sometimes when going up a hill without much load.
The RPM needle sometimes goes out and if I pull wires underneath dash board go back up again. It does not happen all the time.
Any clues anybody?
buickanddeere
07-23-2005 10:40:07
 Re: JD 2355 troubleshooting - synch. transmission in reply to Aefallon, 07-21-2005 06:47:36
Filter and screen? Anthing grity or shinny in the trans oil? Under the dash. Keep looking for something which has vibrated loose over the years.
