2000 HST 4400 Removing Shifter shaft
stuck in high g
07-20-2005 23:59:45
I was going to change gears and the shifter was limp.. Appears the shifter shaft has sheared off at the case, and the rest of the shaft is still secured to the shifter arm. Is it possible to remove the shaft and replace it without splitting the tractor. Hopefully there is an access plate that will allow for removing and replacing shoe to shift collar..
Mike M
07-21-2005 11:57:22
 Re: 2000 HST 4400 Removing Shifter shaft in reply to stuck in high gear, 07-20-2005 23:59:45
If your going to try any repairs on it you better get the FACTORY service manual.Worth it weight in scrap/broken parts.
