Fluid in the wheels - 4020...148 loader necessity?
Nylon
07-20-2005 21:11:48
I discovered that I have fluid in my tires. I have a 148 loader on this 4020. Is fluid needed for that loader or is it more for field work? The reason I ask about necessity is that
it looks like I have to do the brakes and I can't begin to imagine how heavy one wheel is going to be. Is there a rust out problem with chloride? It is a 68 and there is some rust but not bad on the rims. Can they and do they rust through? Thanks for any info,
John
Nylon
07-21-2005 23:19:09
 Re: Fluid in the wheels - 4020...148 loader necess in reply to Nylon, 07-20-2005 21:11:48
We have a 460 with a schwartz loader and no fluid. It does get a bit light with out the back blade on. But it really does just fine.
The manual on the 148 says 4020 needs no extra weight. I have a 7 foot bucket. I now know why i sunk to the bottom of the swamp while mowing. I can sail over it with 460. I will probably keep fluid in them since I have another loader tractor available. Just not looking forward to the brake job with a cab and roll bar.
Jason Z in MO
07-21-2005 10:57:19
John,
As others have said the calcium will rust if there is a leak and will eat through given enough time without attention.
If you do have to replace the tires or have a leak, get the calcium pumped out before you do the brake work. Around here they have been using windshield washer fluid. Not corrosive but doesn"t weigh as much. My feeling is, it"s a good trade off.
You will need that weight for your loader. Tire fluid is cheap ballast as well as easy and out of the way. You could hang a concrete block on the 3-point but then when ever you want to use it for something else... it"s a pain. I prefer the weight on the wheels. The load is only carried by the wheels and tires and no other moving parts of the tractor. Other than what it takes to move the tractor with the extra ballast. With the weight on the wheels (fluid ballast or cast weights) the axle bearings or 3-point parts are not under any load.
I took my tires off filled with fluid but I used the loader of another tractor. Some ideas if you don"t have another loader tractor available...
If you keep the wheel standing up right it will probably be fairly stable. I wouldn"t try it without assistance and a chain hoist or cherry picker.
Jack the tractor up and use a 4 wheeled moving dolly or one of those 4 wheeled car dollies. They have steel wheels. Support the top of the wheel with the cherry picker and chain the dolly under the wheel. You should be able to roll that around. Remember your not trying to carry all the weight on the cherry picker either.
Haven"t tried this either but the front legs of cherry picker might be all you need. With the wheel off the ground slide the picker under the wheel positioning the boom over the top. Let the weight of the wheel rest on the legs and support the top with the boom.
Build a rack to hold the wheel upright if you need the picker to remove the final drive.
Just some thoughts, hope my ramblings give you an idea you can use!
Glen in TX
07-21-2005 07:25:23
You need the weight of the fluid plus some more weights for sure to do any real work with the loader safely. Tire places put in some type of methanol mix in them now. If you don't have any help in handling them with that kind of weight in them have the tire guys come out and pump the fluid out for you in some barrels. That's what I did since they had to order some tires anyway and while I was waiting on tires I got the rust cleaned off rims and repainted before the new tires and tubes went on with the methanol fluid mix.
720Deere
07-21-2005 05:05:46
Assuming that you have 18.4-34 tires, they hold about 90 gallons of CaCl fluid which weighs about 10 lbs per gal. The tire, rim & wheel should weigh at least 500 lbs itself plus the 900 lbs of fluid. You may be close to 1500 lbs per wheel!
It depends on what you intend to use the loader for to determine how much weight you need on the rear. If heavy lifting will be done with it, you may even need a few wheel weights in addition to the fluid. I know a 4020 with a 158 loader that has the tires full and 5 sets of wheel weights and that's just barely enough for what the loader will lift.
Jon (IN)
07-21-2005 04:37:33
The weight in the rear tires really needs to be there to counter balance the load in the loader. Calcium Chloride is fine, until you develop a leak. It will not "eat through" a rim from the inside, but will rust a rim if there is a leak, normally this is seen around the stem. There are better chemicals available now, but I wouldn't replace the CaCl, unless you have true problems.
Yes, them tires are heavy. I have done a few by hand without a loader. only used a comealong hoist and chain. No fun. As long as you keep the wheel standing upright, they aren't too bad. roll the wheel around and then get it back to the tractor and raise and lower the tractor to get it lined up to go back on.
Mike M
07-21-2005 04:32:10
You must have fluid in there for enough counter weight. I have a 4020 with a 158 loader tires full of fluid still needed more weight to be safe ! Got a #115 blade and hung on the rear and that makes it just right.
txgrn
07-21-2005 05:15:33
 Re: Fluid in the wheels - 4020...148 loader necess in reply to Mike M, 07-21-2005 04:32:10
Hmmmmm I had the same rig and put new tires on the tractor so I know there was no fluid in the tires and I didn't have any problems on slow rolling hills type terrain. I could pick up a 5x6 bale of hay or a bucket full of rocks and it did ok.
I know it was heavy cause even with 35 psi in the front fat tires (forget dimensions) they would squash with some loads..... Dunno.
Mark
Mike M
07-21-2005 05:25:38
 Re: Fluid in the wheels - 4020...148 loader necess in reply to txgrn, 07-21-2005 05:15:33
I can't remember for sure but I think I need to run about twice that air pressure. How big a bucket ? ours is 8 footer you get it full of wet dirt/mud and you really got a load. How much does one of those bales weight ? I pick up disabled JD B tractors and move them around. I can't lift a model A unless some parts are missing like the cast rear wheels. This is also on less than flat ground live on the side of a hill. Have to use tire chains in the winter too!
txgrn
07-22-2005 05:32:03
 Re: Fluid in the wheels - 4020...148 loader necess in reply to Mike M, 07-21-2005 05:25:38
8' bucket was on mine or I'd install a hay spike in the winter. Bale weight on 5x6 rolls could be as high as 2000#.
On the side of a hill, I think I'd go with rear weights and remember to keep the load as close to the ground as possible whenever possible and no sharp turns.
Good luck.
Mark
mike brown
07-21-2005 03:41:44
That weight sure is a good idea with a loader! Imagine having the rear wheels get light when you have a load in the bucket. Calcium chloride will cause the rims to rust.
The manual that came with my loader listed which tractors need extra weight for safety.
Ken in Mich
07-22-2005 17:49:10
 Re: Fluid in the wheels - 4020...148 loader necess in reply to mike brown, 07-21-2005 03:41:44
I bought a new JD tractor/loader a few years ago, and the dealer put a fluid called "rim saver" in the tires. He claimed it was non corrosive, doesnt freeze, and made out of beet juice.
