Does Anti-siez attract water?
Kurt_JDB
07-20-2005 15:28:56
I am in the process of rebuilding the fanshaft on my "51 B. The fan shaft clutch and keeper lock were corroded and rusted to the shaft. I had a machinist help me get it apart by cutting these parts. I would like to put something on the shaft to make future service and dissasembly easier. I have heard that anti-sieze compounds attract water, and that they may cause problems if used where rain may get to it.
I have two questions:
What do you recommend to use to keep the fan clutch parts from sticking to the splined fanshaft?
I got new clutch cups for the fan clutch. They came unpainted. Should they be painted?
Thanks, Kurt
johnlobb
07-25-2005 17:16:50
 Re: Does Anti-siez attract water? in reply to Kurt_JDB, 07-20-2005 15:28:56
I am a pipefitter, and when breaking flanges apart on a refinery shutdown (almost everything is outside) we always antiseize the bolts when we put them back together, You can always tell when the person who put the flange together used antiseize. If not, you"re in for a rough time. (Neverseize is a brand name). Use it whenever you want to take something back apart again later. Good luck!
Mike M
07-20-2005 18:33:11
I have used neverseze on them. The truck mechanics always used that stuff on the wheel studs and they see lots of salt water around here in the winter.
KIP in MX
07-20-2005 18:10:26
If you can find it, Mastinox is great for that kind of application. Just don�t get it on your skin.
