JD, there are a few who burn Kerosene or other similar blended heavier fuels like Distillate (if you could buy it, cant for years, some blend gas and No. 2 I believe) in the big main tank on all fuel tractors for nostalgia and the smell etc. HOWEVER, most all including myself just run gas in the tractors (usually only the big main all fuel tank). If you run distillate or Kerosene you have to have an all fuel carb plus the hot all fuel manifold plus warm her up to 190 or so BEFORE you switch to fuel and then run gas through it prior to shutdown to purge the carb. It would be much better if you used it under full load at full RPM and temps over 190 to avoid plug fouling which is hard enought to avoid in light use cool running parade only tractors. I run gas in the big main tank,,,,, ,use shutters to get temp over 180,,,,,use wire core plug wires,,,,, ,use hotter then specified plugs,,,,, ,,and keep the ignition tuned perfect and dont run the carb over rich all to avoid plug fouling in parades so Id hate to try n avoid fouled plugs in a pardes running kerosene or distillate myself, but thats just my thoughts, Im NOT any fuel expert. Interesting subject John T
