720diesel tune up
goober720
02-28-2004 06:00:55
I have a 720 diesel that is being restored for pulling and for use.Ihave completely overhauled the engine with new .090 pistons,valve job and injector and pumps are rebuilt.I was wondering if anyone could give a little help with tuning the injection pumps and governor as I will be pulling against guys who seem to have much larger wallets than I do. thanks for any help, the book is rather vauge on this subject.
buickanddeere
02-28-2004 13:33:08
 Re: 720diesel tune up in reply to goober720, 02-28-2004 06:00:55
Is it all back together? A cam from Roberts and some valve/valve bowl work in the head holds some power. Without the increased airflow adding fuel just makes smoke. Steve Crum makes low restriction exhaust manifolds and Alert at Renaissance had low restriction airfilters. The 720 already has the big 13mm injection pumps. Which tips are in the injectors? What pressure does the fuel transfer pump have?
goober720
02-28-2004 19:50:31
 Re: Re: 720diesel tune up in reply to buickanddeere , 02-28-2004 13:33:08
I have already done quite a bit of polishing in the ports,removed the oil bath air filter insides and replaced them with a paper element.I haven't run it yet because I am waiting to get the pumps and nozzles back from the rebuilders so I don't know what tips are in them.I was wondering how high I can run the fuel pressure.I work on Mack trucks for a living and I know you can run 30-40 psi in them and get away with it.
