JD 3010 Gas Engine Runs Rough During Load
Charles Beavers
07-20-2005 07:03:32
I recently had my JD 3010 gas carburetor rebuilt and new points, condenser, plugs and timing done. It worked good for about 2 hours and then while going up an incline the engine started missing. It will also flutter a little while in park and opening the thottle quickly.
Since the carburetor was rebuilt, the load screw opens out only 3/4 of a turn for best performance. The shop manual says it should be about 1 3/4 turns. Is it possible the carburetor is still not totally correct?? It was rebuilt by a professinal carburetor rebuilder.
Any help or suggestions will be greatly appreciated.
Mike M
07-20-2005 07:34:13
 Re: JD 3010 Gas Engine Runs Rough During Load in reply to Charles Beaverson, 07-20-2005 07:03:32
If you have one of those MS aluminum carbs. I don't think you have much of a chance of it running consistantly no matter how good the rebuilder is. It may of picked up some crap plugging it up as there really is no filter maybe only a screen.
Charles Beaverson
07-20-2005 12:49:03
 Re: JD 3010 Gas Engine Runs Rough During Load in reply to Mike M, 07-20-2005 07:34:13
Mike,
I have a Zenith Carburetor which was just redone by a local carburetor rebuilder.
I've installed a new coil, plugs, condenser,and points. I set the timing to 20 degrees BTC @ 1900 RPM's as per the I&T shop manual. The tractor still misses when pulling uphill (I think it misses more as the engine gets hotter).
Any additional help will be appreciated.
Thanks Charles
Mike M
07-21-2005 05:28:27
 Re: JD 3010 Gas Engine Runs Rough During Load in reply to Charles Beaverson, 07-20-2005 12:49:03
Try opening up that load adjustment as when you pull one of those down they like LOTS of gas.
