Hoff, I know your frustration, been there MANY times. We know the starter is good, so you would have to one by one isolate problems AHEAD of the starter. 1) TO TEST THE SOLENOID: Take a jumper wire and attach a hot 12 volt feed, like from the hot supply side to the solenoid (thats NOT the side to starter) over to the solenoids small activation terminal and the solenoid should pull in and the starter turn IF THE SOLENOIDS GOOD. 2) IF THE SOLENOID CHECKS GOOD (i.e. jumping its lil activation terminal makes it work) next take a test lamp and place it on the solenoids lil activation terminal AND WHEN THE KEY IS HELD IN THE START POSITION IT SHOULD LIGHT UP (voltage there is what makes it pull in and engage the starter, i.e. the solenoid closes) 3) IF THERES NO HOT VOLTAGE GETTING TO THE SOLENOIDS LIL ACIVATION TERMINAL WHEN KEY IS IN START POSITION; Theres EITHER,,,,, ,,,, a bad/open Neutral switch (when in neutral a lil switch closes),,,,, ,,,,, or a bad/open blade disengage switch (closes if blade engaged but opens otherwise),,,,, ,,,,, or the switch is bad,,,,, ,,,,, ,or theres no voltage present at the switches BAT input terminal,,,,, ,,,,,or thers an open fuze or open wire in the switch circuit or from the switch to and through the safety switches (Neutral and blade) to the solenoids lil activation terminal. Shes NEVER gonna crank until the solenoid is good and theres voltage (when in Start position) gettign to the solenoid. That path is out the switches Start terminal,,,,, ,to n thru both safety switches (Neutral and blade) ,,,,, then to the solenoid. The switch gets its BAT input voltage from the ammeters load side, so IT MUST BE HOT WITH BATTERY VOLTAGE ALSO AT ALL TIMES. The switch cant provide voltage anywhere unless it has a voltage input!!!!! !!!! The ammeter MUST show hot voltage on BOTH its terminals. The supply side MUST be connected to the battery while the load side must feed the switch and receive charging voltage from that regulator/rectifier aluminum block. My best guess is still one of the safety switches (Neutral or blade not engaged) is bad/open or theres a wire open or missing in the start circuit from the switch to n thru the safety switches to the solenoid. If a hot jump to the solenoids lil activation terminal makes her crank, check that circuit from the switch thru the safety switches to the solenoid. Sorry, thats about the extent of my knowledge on those mowers but a test lamp and voltage check at those critical points ought to isolate the problem. Good luck n best wishes, let us all know John T
