3020 oil pressure warning light
bill in mi
07-20-2005 05:34:09
My Dad has a 3020 with a problem in the oil light circut. When you turn on the key switch it no longer lights before it starts to check the light. If you turn on the main light switch the light comes on. I have checked the wire from the pressure switch and it is ok. I have replaced the pressure switch with a new one and also checked the switch and it is ok. Does anyone have ay ideas on how to correct this? Thanks BIM
msb
07-20-2005 22:08:18
 Re: 3020 oil pressure warning light in reply to bill in mi, 07-20-2005 05:34:09
It must b a diesel .The small ground wire on the left battery needs replaced.
Chip
07-20-2005 17:26:44
You say when you turn the lights on it comes on, It's probably plugged into the wrong switch. The sending unit grounds the circuit,the wire runs up to the warning lite, the wire then goes to the switch to get 12volts. When the key is turned on 12volts go to the warning lite and lite the bulb because the sending unit is grounding the circuit, start the engine and the sending unit quits grounding and the bulb does not lite anymore. You check the sending unit with a test lite,no oil pressure should lite the test lite, start the engine and the ground is gone and the test lite won't lite.
Rodney A. Johnson
07-20-2005 06:54:01
This probably won't be much help, but....
When this happens on my 3010D, it is because the fusable link between the battery and the frame is bad. The light doesn't work no matter what until the fuse is replaced or the wire fixed (I've had to do both over the years). My 3010D is still on the 24 volt setup.
bill in mi
07-22-2005 14:40:35
 Re: 3020 oil pressure warning light in reply to Rodney A. Johnson, 07-20-2005 06:54:01
Thanks to all who responded. It turned out to be the link on the left battery. Someone put a glass fuse in the line and it was blown. What caused the fuse to blow was that at the light socket the wire had a couple of frays and they were shorting out the light. Thanks for your time as it was drining us goofy trying to track this one down BIM
