4020--how much smoke is too much? :] (diesel)
Nylon
07-19-2005 21:56:27
I notice smoke coming from below/ side...not alot but some. I noticed it when looking at it from behind with the sun shining on it just right. This the crank case breather?
There is some exhaust smoking. Engine seems to run well but I don't know how much or if it should be pretty much clean.
txgrn
07-20-2005 05:45:09
 Re: 4020--how much smoke is too much? :] (diesel in reply to Nylon, 07-19-2005 21:56:27
Yeah it's the breather tube. If it bothers you you can tap into the intake manifold and route it there. I use a piece of garden hose and a 1/2" pipe to hosebarb connector on the manifold.
On smoke, those engines smoke; at least mine do...but I have no idea how long since rings on either of them.....but I have a 4230 which is a newer version of the 4020 400 cu in engine with 4000 hours on it and it doesn't smoke.
I wouldn't worry about it if it runs and starts good unless it looks like a steam locomotive stack of the old west period.
Mark
Nylon
07-19-2005 22:02:34
I forgot to mention that diesle starts right off. it is 12 volt on dual batteries...but so far in warm weather it starts immediately.
