4010---4020
marlbourne
07-19-2005 18:41:13
what differnces are there in a 4010 and 4020
Whitefield
07-20-2005 08:27:48
 Re: 4010---4020 in reply to marlbourne, 07-19-2005 18:41:13
In my opinion the most important difference between the 10 & 20 series is the PTO design. If you plan on using the tractor for much PTO work go for the 20. The 10 shifted from 540 to 1000 by bolting on a different stub shaft. The 20s used a slide-in stub shaft retained by a snap ring. They are stronger by far and more reliable. If you have trouble with your 10 PTO- get your splitting stands out...
Early 4020 did have 3 reverse gears like the 10 until the end of 68. Then they went to 2. The powershift was available on 20 from the start in 1964. The 4010 was built in 61,62,63. The 20 was built from 64-68, and then 69-72 with the side console & up the 3 hydraulic remotes & PTO on the dash & oval muffler. You can't get a differential lock on 4010. Like the other poster said- the engines didn't all start out as 404 diesels but they are now. Maybe someone else knows when they started using an alternator instead of a generator. A 72 4020 will only have one set of front facing fender lights instead of two sets. A 4010 has a green dash with a black instument panel & a 20 has a black dash & panel. 20 has PTO lever on RH side of cowl until 68-69 change to dash. 10 has lever on LH side of cowl.
That is about all I know.
wilamayb
07-21-2005 12:28:30
 Re: 4010---4020 in reply to Whitefield, 07-20-2005 08:27:48
My 69' Console model 4020 has 3 reverses. The one below 4th and 7th makes 3. It will move faster than I can back a wagon!!!!!
Whitefield
07-22-2005 09:38:51
 Re: 4010---4020 in reply to wilamayb, 07-21-2005 12:28:30
I'll be darned- I thought sure those models only had 2 Reverse gears- Wrong again!
I'll bet that is faster than you can back a wagon- the 2nd reverse is too fast for me!
Rodney A. Johnson
07-20-2005 06:45:46
Items that haven't been mentioned that come to mind:
Hydraulic lines on 4010 are smaller then on 4020. Hydraulic pump on 4020 was 2 gallons more flow and 200 psi more pressure out of the factory.
I believe the castings of the parts were heavier on 20 series. Reason I state that is comparable tractors (similar options) have big differences in weight.
My 3010D had a shipping weight of 6000. A 3020D had a shipping weight closer to 7500. Was told by a sales person that a 4010D I was interested in was only 15% heavier then my 3010D. That makes it around 7000 (if I did my math right). The 4020 I have has powershift and a cab, so is approximately 9000. Without cab and powershift I would be somewhere around 8300 I think.
I think typically the front tires were bigger on 4020s.
The later model 4020s (and 3020s) had side consoles (after '68 I think).
j cook (iowa)
07-20-2005 06:13:19
The hydraulic couplers on the -10 series are different from those on the -20 series. The -10 series transmission has a third reverse selection, found in the 4-7 quadrant which was eliminated in the -20 tractors. Powershift was not available in the -10 tractors either. The axle diameter in the 4020 is larger and I think that the transmission gears themselves are a bit heavier. Displacemnt of the 4020 engine is greater, 404cid vs 380cid (although the overhaul kit for the 4010 used 4020 sleeves and pistons so there are by now very very few 390cid engines left). The 4010 had a sort of "booklet". located under a cover on the dash---not there in the 4020. The location of the pto lever was also chamged, and a power differential lock was available on the 4020.
JWhite
07-19-2005 22:06:52
4020s had a larger engine than the 4010. The early 4020s had the same hydrolic system and controls (consode mounted) and the later 4020s had the more familiar side controls. The later 4020s also had the power shift as opposed to the earlier synchro shift transmittion which was the same as the 4010. I think the 4020s (especially the later ones) came standard with 2 remote hydrolics>
txgrn
07-20-2005 05:48:28
 Re: 4010---4020 in reply to JWhite, 07-19-2005 22:06:52
Yup on the engine; 300 cu 80 hp vs 400 cu in 96 hp. Tires 16.9 x34 vs 18.4 x 34. My 10 has dual remotes whereas my 20 didn't but it was an earlier model. Can't tell (I can't)the tractors apart sitting in the seat.
Mark
