'74 JD 110...HELP!!!!
Hoff
07-19-2005 18:16:36
Guys,
You've all been a big help...this is my final plea for any other ideas before I have my repairman fix the tractor. Just to remind all of you...this is a 1974 JD 110 8 HP Kohler. I still have nothing when I try to start it. not a click or anything. I have replaced the battery, key switch, selinoid, coil, condenser, and ignition fuse. I have over 100 worth of parts into it and still not a damn thing. Any ideas at all??!? Anything would be much appreciated. I'll look forward to your responses. Thanks!!
jas
07-19-2005 18:50:45
 Re: '74 JD 110...HELP!!!! in reply to Hoff, 07-19-2005 18:16:36
take a battery and some jumper cables and connect the neg to ground somewhere on the motor. then take the positive cable and touch directly to the starter post. the engine should turn over. If not, the starter is bad or the motor is locked up somehow. ps. make sure it is in nuetral and the blades shut off because you are now by-passing everthing.
