720D Pony Motor Starter Problem
tsmith1499
07-19-2005 17:54:55
Starter motor for Pony runs but will not engage into flywheel of pony motor. I took the startr off the pony motor and cleaned it up and WD-40'd the heck out of her. Starter motor turns over great but gear will not kick out to engage. I have never taken one of these apart. Any ideas? It was working great until about a week ago. I can move the bendix gear freely on the shaft, in and out and just don't know what it could be. HELP !! Thanks, Tom
WeirdDeere
07-20-2005 11:33:23
 Re: 720D Pony Motor Starter Problem in reply to tsmith1499, 07-19-2005 17:54:55
Do you have a good charge in the battery? I had your problem once, my battery was low, and wouldn"t spin the starter fast enough to engage the bendix gear.
Good luck!
Brandon
Mike M
07-20-2005 05:23:05
Are you testing it on the workbench with a battery and cables to verify that it is indeed not going out ? Usually just cleaning them up is enough to get them to fly out ?
tsmith1499
07-20-2005 14:23:48
 Re: 720D Pony Motor Starter Problem in reply to Mike M, 07-20-2005 05:23:05
Yes the battery is fully charged, and yes I also have it in a vise on a workbench and am using a battery charger set to 6V high. The starter motor spins like crazy, but the bendix just won't engage. I found a dealer in MO. that has one in the box from Deere for $37.50. I called another dealer that had one and they wanted $90.00 ! It pays to call around. The starter drive (bendix) is obsolete from Deere. Thanks for the help, I am going out tonite and take it apart and see what's inside. Tom
Van in AR
07-20-2005 19:10:15
 Re: 720D Pony Motor Starter Problem in reply to tsmith1499, 07-20-2005 14:23:48
A battery charger will not put out enough amps to properly spin that starter. Try checking it with a battery and jumper cables.
Van
