36 A massive coolant leak into crankcase
Wendel
07-19-2005 13:40:49
This will leak 2 gallons over night haven't tore it down yet the bolck has been bored and checked for cracks this was a running tractor. Has no sign of water in combustion chambers thought at one time I seen something about lining push rod tubes with copper tubing
John T
07-19-2005 14:52:35
 Re: 36 A massive coolant leak into crankcase in reply to Wendel, 07-19-2005 13:40:49
Wendel, Ifffff fff its a pushrod tube leak,,,,, and Ifffff fffff its leaking that bad,,,,, , if you remove the valve cover and park her front downhill you would see water trickling down n out those tubes. Those type pushrod tubes were on some heads not others, Im unsure on your tractor.
John T
Maark
07-19-2005 13:52:48
Those pushrod tubes are your likely suspect. They will corrode over the years or someone installed longer manifold bolts and crushed the tubes. Available from Deere.part# AA1615R
Wendel
07-19-2005 20:11:56
 Re: 36 A massive coolant leak into crankcase in reply to Maark, 07-19-2005 13:52:48
Thank you both for your help took the valve cover off tonight seen 2 trails of rust one was from the studs that hold rocker shaft on the head filled cooling system and watched only seen from studs. But the other trail was from the intake push rod hole for #2 cylinder and we did install a new manifold so I'm the dummy here thanks again very much.
Wendel
07-20-2005 03:57:54
 Re: 36 A massive coolant leak into crankcase in reply to Wendel, 07-19-2005 20:11:56
Don't have a manual for tractor this old do the tubes taper and or can they be replaced with head installed??
Earl -IL
07-20-2005 08:49:43
 Re: 36 A massive coolant leak into crankcase in reply to Wendel, 07-20-2005 03:57:54
Here in Illinois we have a lot of mineral in the water.The lime will build up around the tubes.You have to get the lime build up out of the head or the new tubes will cock over and not go in straight.I have done 20 'A" & "B"s over the past 30 yrs and I prefer to remove the head to remove the tubes . Then I take a torch and heat the lime deposits. They will pop loose when hot. Be careful on tube removal. I use a bushing driver that is .005 smaller than the tubes OD. on the small end. Press the tube to the rocker arm side of head, press from the valve side .Clean and inspect make sure the area in the head where the tubes push in doesn't have scratches .I use JB weld on the ones with scratches,white lead or teflon thread seal on the smooth ones.Your tubes have a big end that goes to the rocker arm side.Press or tap in from that side.Save and mark your tubes in case you have a oversize hole.On those you will have to make the tube. Earl In Illinois
Mike M
07-20-2005 05:32:56
I did the ones on my B with the head installed. I ran a tap into the inside of the tube my B was 3/8 NPT don't know if that A is any bigger ?Then I made a puller out of threaded rod and a pipe nipple to thread into the now taped tube. Slip a larger dia. pipe over it all and install a washer and nut and pull the tube out of the head and up into the tube. I had some trouble with my cyl. head having different sized holes so the new ones didn't all fit tight as they should. Swaged them out with a tapered punch and ended up putting JB weld on them to help seal them.
