Differential lock on 4850 MFWD
DICK68
07-19-2005 05:53:48
Found a 4850 at very reasonable price. The owner says the only problem is that the differential lock on the MFWD would not engage in tough conditions. Could any one tell me if this would lead to high expenses for repair ? Another point is it has had the cylinder head gasket changed 3 times during its 7500 working hours. Is this a weak point on the 4850s ? Are there any other weak points to be checked when buying this model (15 PS trany) ?
G/MAN
07-20-2005 07:30:30
 Re: Differential lock on 4850 MFWD in reply to DICK68, 07-19-2005 05:53:48
The higher-horsepower 466s can be a little hard on head gaskets if they're turned up much or lugged a lot. If the head and deck are flat, the liner protrusion is correct, and new cap screws are installed using the PROPER torque specs and sequence, they hold up much better. The 6076 engine eliminated a lot of the head-gasket issues. Due to a thicker head surface, I believe. On the MFWD issue, is he referring to the MFWD clutch itself, or the limited-slip? Could be a problem in either one. The MFWD clutch is spring-applied and is released by hydraulic pressure. If the spring is shot or the clutch disks are missing friction material, it could easily be slipping. With three head gaskets and now MFWD problems at 7500 hours, I think this old girl might have been leaned on a little bit. I believe I'd keep looking. There are nice, well-maintained low-hour tractors to be found in that series yet. You'll pay more, but it also might be cheaper in the long run.
buickanddeere
07-19-2005 08:18:37
Head gaskets will last if the tech doing the job knows his stuff. If the fuel rack turned up? The front diff is just a limited slip clutch plate type. Track Tech will sell you a real Detroit Locker for the front axel. Or does the vender mean the front axle won't drive at all? Run an oil sample of both the engine and trans. Check the ph of the antifreeze.
