Hydro-Trol Pressure
uglyoldA
07-19-2005 02:55:59
I just got the parts I needed (Expo)to get hydraulic out of my '51 A - got it hooked to my wood splitter and it worked !! It is kind of slow which I expected , but I could stand a little more pressure . In the book 1500 is the number , I'm gathering the parts to check to see what I have but I was wondering has anyone seen more than 1500 ? Thanks george.
Bozo
07-19-2005 20:40:14
 Re: Hydro-Trol Pressure in reply to uglyoldA, 07-19-2005 02:55:59
Just came in from the shop, styled AR , 50, 60 and 70 about 950. If I remeber the A, B and G were 650 for working pressure and about 9 gal/min for the A and first numbered series. Max 150 - 200 higher.
mitchp
07-19-2005 07:44:53
i would be careful not to run that wood splitter for long periods of time, that tractor doesn't have a oil cooler on it and splitting the wood will get the oil very hot and could do damage.
Mike M
07-19-2005 05:44:19
Those old ones are only made to run somewhere around 800-1000 psi can't remember exact number. I guess you can shim up the relief and see if you can split the pump.
