John, First of all, before you start get the manuals. The JD service manual is expensive but worth every penny. I think you can get it on CD which is much cheaper. You can print the section you need. The axles and axle housings are called the final drive. The final drive comes off as an assembly. There is a ring of about 12 bolts that bolt it to the differential case. You do have to remove each final drive to get to each brake. Be sure to do one side at a time. I removed the wheel before I pulled the final drive. If the wheels haven"t been moved in a while you might have some trouble getting them freed up. Search this web site; several discussions have talked about this issue. For safety, when I worked on the right side I moved the left wheel out to the end of the axle and blocked directly under the differential, basically under the drawbar. Yes, the metal can get into other systems but they are protected by the transmission filter. The oil is sucked through the sump screen then through the filter which feeds the main hydraulic pump then off to all your hydraulic systems. However, there is a safety check valve if the filter becomes clogged it will bypass the filter. First thing I would do is check your filter. I don"t know how the cab mounts to the tractor but I assume it bolts to the final drive housings. If so, you will need to block it up when working on the brakes. If you want to fix the 3-point, I would guess the cab would have to come off. I haven"t worked on the 3-point cylinder but I do know it is internal. I believe you have to remove the seat assembly and rockshaft housing/cover. It"s not accessible from the outside. In your case the cab probably has to come off. As far as I know... Hang it from a big tree if you don"t have any other options... :)
