If so equipped from the factory, a 620 should have what is called the "square" wide front end, the center casting is more or less square, and the outside tubes and spindle knees fit into a round bore in the center casting. It could also be equipped with the "round" wide front end, in which the center casting is round, and should bear the casting number B2690R. These front ends were not available as a factory installed item, but a lot of them got installed from earlier tractors at the dealer level, There is no way to determine how many 620 LP's were equipped with wide front ends from the factory. Personally, I think the serial number searches available from Two-Cylinder are worth the cost. They confirm your tractor, will tell you chassis configuration, whether the tractor was equipped with power steering, the shipping date, and shipping destination. I don't know if the 20 Series book by J.R. Hobbs is still available from Green Magazine or not, but it would be worth a call. ASAE might still have some copies left. Good luck with your 620!
