JD 110 electrical issues...
Hoff
07-18-2005 17:22:05
Guys,
First of all, thanks for ALL of the help you've provided. However, my issues continue. Still haven't gotten the '74 110 (8 HP Kohler) going yet. Here's the story and if anyone can help, it would be much appreciated. Ok..the tractor has a new battery and still will not do anything at all when I try to turn it over, no clicks, no nothing. I went through and cleaned all of the electrical parts and still nothing. On the advice from my repairman, I replaced the fuse that goes from the ignition to the starter (13 bucks for a fuse!!!). Still nothing. Also installed a new ignition switch..and still nothing. I tried readjusting things and looking around and cannot figure out what the problem is. However, when I take my trusty rubber handle screwdriver and connect the "long screw to the short screw" I get tons of spark and the starter turns. So...what does that mean? Is there anything that I can rule out that is not the problem since the tractor does this?? Also, I have the thought that this might be a faulty neutral start, I took the gear case off tonight and looked at the wire, looks pretty worn. If I just disconnect the wire, will this bypass the switch and run anyway? I hope I'm making sense...but I have spent a very long time working on my beloved Deere and it's just not paying off. Any help would be welcomed. Thanks guys...
John T
07-18-2005 19:53:41
 Re: JD 110 electrical issues... in reply to Hoff, 07-18-2005 17:22:05
Hoff, based on what you say, the only things I can rule now are the starter motor itslef must be okay. However, I cant say for sure if the starter solenoid is good or not cuz Im unsure if youre jumping 12 volts to the solenolids lil activation terminal (which activates it) or if youre jumping the starter direct i.e. the big cable down from the battery gets jumped to the starters main input lug.
My best GUESS is the neutral safety switch is NORMALLY OPEN meaning to jump by pass it the 2 wires it to it would have to be tied together n see if she starts then???? I think when the starter switch is turned to the spring "to start" position the voltage n current path is from that "to starter solenoid" switch terminal,,,, to n throught any safety switches (such as Neutral and blade NOT engaged),,,, then to the lil activation terminal on the solenoid. Sooooo o there must be an open circuit there like either the Neutral switch is open or the blades disengaged switch must be open.
Get a jumper wire and jump hot 12 volts to the lil activation post/terminal on the solenoid n see if the solenoid pulls in and she cranks????? ???? Thats NOT either of the 2 larger posts which are the solenoids input and the starter post. If a hot wire to the solenoids lil activation terminal makes the solenoid engage, then the problem is either one of the safety switches (Neutral or blade NOT engaged) is bad/open or theres no power to the switches BAT input (open wire or fuze) or the switch is bad. If the solenoid fails to engage if power is applied to its lil activation terminal, then suspect a bad solenoid.
All it takes is a simple 12 volt test lamp to diagnose this so see if the switches BAT input has voltage (from the ammeter maybe via a fuze) and then if its terminal to the starter solenoid (hot when in start position) is hot when in the start position and then see if it gets thru BOTH safety switches and then its supposed to activate the solenoids lil activation terminal.
Keep the faith, you can fix it
PS did you download the Kohler info Bob posted for wiring info?????
John T
