Did my transmission just fail?
TonyInKY
07-18-2005 16:12:46
I have an STX-38 yellow deck. I was mowing the lawn when I noticed the shifter was acting odd. Almost like it was very sticky. Then, it stopped going into gear, forward or reverse.
Nothing was obviously disconnected on the outside of the transmission. If the problem is inside the transmission, I fear my 1992 STX-38 sleeps with the fishes.
Any diagnostics I can do?
TonyInKY
07-19-2005 20:29:43
 Re: Did my transmission just fail? in reply to TonyInKY, 07-18-2005 16:12:46
After the machine cooled, I went to look at it and the main problem is that a belt has slipped off the pulley that is on top of the transmission.
The belt seems to be in good repair.
The pulley, however, wobbles. I am guessing that it isn't supposed to :-D
It's also difficult to get to the pulley to remove it. Looks like the back axle has to come off. What is that, remove 4 bolts and some linkages?
I don't have a great place to work on it, or any jackstands, etc, so it's had to see under it. But I didn't see an idler wheel anywhere. How does one (de)tension the belt properly so it can be slipped back on the pulley?
Joe Padavano
07-18-2005 17:56:57
You didn't say what trans it has, but if it's the 5 speed gear trans, it's a Peerless (by Tecumseh). I just finished a rebuild on the same trans in my JD160 (precursor to the STX38). These transmissions are very easy to rebuild and parts are available from JD and other aftermarket sources (for less money than JD).
The most common failure is the spring keys that engage the gears when you shift. These are spring steel and have teeth that slide into notches on the inside diameter of each drive gear, depending on which speed you select. The teeth tend to round off with use, particularly if the tractor has been shifted without using the clutch. (Don't ask how I know that...) They also loose their springiness over time, leading to further slippage. The good news is these keys cost about $11 each from JD and there are two of them in the trans. The bad news is that you just about have to take the trans completely apart to replace them.
The hardest part about rebuilding one of these transmissions is cleaning out the old lube. The trans is sealed and uses a special high-viscosity lube called "Bentonite". It has the consistency and stickiness of molasses. You need to use the same lube when you rebuild the trans.
Joe Padavano
jdgreenblood
07-19-2005 11:24:12
 Re: Did my transmission just fail? in reply to Joe Padavano, 07-18-2005 17:56:57
the shifter was probably loose. this happened to my 38.
