G sounds like it is under heavy load
Mike w J
07-18-2005 15:40:54
I have a 1952 G that ran good a year ago but now it sounds like it is working at idle or sped up. when you slow it down from fast idle it will backfire. the roter has what looks to me like to much free travel if you look at it from the end it will turn from 12:00 to about 2:00 or close to 2:30 with no resistance. where does all this free travel come from ? could it have a bad bearing ? I advanced the timeing about 1/4 in on the markings and it run better at a steady speed but when speeding up or down it will backfire .I changed plugs and wires with no improvment. Any ideas would be helpful THANKS Mike
Pat Browning
07-18-2005 16:06:59
 Re: G sounds like it is under heavy load in reply to Mike w J, 07-18-2005 15:40:54
Could mud daubers have made a deposit in your air intake path? Remove the basin of the oil bath air cleaner to learn if you see a major difference. Place and old towel under the air cleaner to catch the oil drippage.
I might be suspect also about some blocked passage ways in the carburetor. The BOWL VENT PATH in particular is in mind.
Asside from the BOWL VENT path, we also ahve testing of the LOAD & IDLE passageways -- here's a three-step process for that:
(1) CAUTION: This test involves radical adjustment of both the LOAD & IDLE needles. Before starting the engine, observe the position of each needle lever, and count the number of turns OUT that each of the two needles is at so that you can put them back where they were before this test is run. (2) With the tractor running at least at half-full engine speed, turn the LOAD needle all the way in. The engine will continue to run if the IDLE SYSTEM is open, and if it stops running, -- the idle system IS NOT open! Assuming this test is a pass, reset the LOAD needle where is was and go on to test two below. (3) With the engine running at least at half-full engine speed, turn the IDLE needle all the way in. The engine will continue to run provided the LOAD FUEL system is open, however, in this mode, engine operation will be a throttling pattern. As engine speed drops, the governor will open the throttle to draw LOAD FUEL because the idle path is closed. This pattern, however, indicates the LOAD FUEL channel is open & working as it should. If the engine stops running, the LOAD FUEL channel is blocked.
Hoping you find your problem soon -- PatB
Dave in SV
07-23-2005 16:50:42
 Re: G sounds like it is under heavy load in reply to Pat Browning, 07-18-2005 16:06:59
... but what about his observation that the rotor has what appears to be a lot of free travel?
G/MAN
07-18-2005 15:43:32
My first check would be that the advance mechanism in the distributor is free (not stuck) and is functioning correctly. If your timing doesn't advance as the engine speeds up, it's not going to run right. Remove the rotor and the cover over the points and make sure the weights are free, etc. My two cents.
