Hi fiddler -- before you panic, there should be found THREE timing marks on the gear that goes onto the cam shaft. One is a "V" which is to correspond to a "V" on the cam shaft. Then on each side, you will find a tooth with a timing mark on it, ONE ON EACH SIDE! The mark on the INSIDE is to align with the mark on the crankshaft gear. The mark on the OUTSIDE is to align with a correspoonding mark on the governor gear. Hopefully, you were getting these two confused. Now -- while it is highly unlikely that any of these marks are missing, there is a trial & test, trial & test, etc. procedure for valve timing as outlined in the JD-4 Shop Service Manual. The relevant paragraphs are listed below. If you need someone to talk with, give me a call 830-627-0430. (PatB Para 60. Valve Timing. Valves are properly timed when camshaft gear and crankshaft gear are meshed to that timing marks are in register. To check valve timing when engine is assembled, first adjust tappets (hot) to 0.015; then, check the position of the flywheel on the crankshaft as out lined in para 110 (below). If the flywheel has been installed incorrectly, remove the flywheel and reinstall in the correct position. Turn flywheel in normal direction of rotation until exhaust valve of left cylinder is just beginning to open (0.000 tappet gap). At this time, the flywheel mark "L.H. EXHAUST OPEN" should be in register or within 1/2 inch of index mark on gear case. If timing marks are not as specified, it will be necessary to retime the valves as outlined in para 64 below. Para 64. On the H series tractors, loosen the governor case retaining cap screws and remove camshaft left bearing housing (or cover on earlier models) and remove the left bearing. Remove belt pulley and clutch assembly as outlined in para 180 (below), then remove the reduction gear cover and loosen the camshaft right bearing housing. Lift end of camshaft up so that camshaft gear and crankshaft gear are out of mesh; then turn crankshaft until valve timing is achieved. Recheck tappet adjustment and ignition timing. Para 110. Flywheel and End Play -- R&R and Adjustment. To remove the flywheel, a. Remove the cover (electric start) b. Loosen hub bolts and slide flywheel off shaft. c. When reinstalling flywheel, make certain that the pin in the flywheel aligns with notch in spacer, flywheel is installed in correct position on shaft, and securely tightened. d. Deep keyway of flywheel should be placed over locating screw on shaft, or If the wheel hub carries a rivet, the rivet should be engaged with cutaway spline of shaft. e. The "V" mark on flywheel should be in register with "V" mark on shaft. f. The position of the flywheel on crankshaft control crankshaft end play; move flywheel in or out on shaft to obtain a minimum of end play (0.005 - 0.010) without causing binding. g. Starter ring gear can be driven off flywheel and a new one shrunk on. A mild application of heat on the gear is sufficient to provide the required expansion. h. Install new ring gear with beveled edge of teeth away from the crankcase. Para 180. Clutch Pulley and Sleeve -- R&R. To remove the belt pulley assembly, a. Punch correlation marks on the clutch fork shaft (PC304, 10-56) and the shaft lever (PC304, 10-53) for reassembly reference. b. Punch correlation marks on the clutch fork shaft (PC304, 10-56) and fork (PC304, 10-60) for reassembly reference. c. Remove shaft lever (PC304, 10-53) and pulley brake bearing (PC304, 1062) d. Remove shaft bearing (PC304, 10-54) from top of gear cover e. Withdraw the fork shaft from above & the fork from the front. f. Remove clutch disc (para 52) and clutch pulley (PC304, 10-16) g. On the '39 H, snap ring (PC304, 10-10) must be removed before removing pulley. ++++
