Battery ?
georgec
07-18-2005 05:40:46
I need to know how many Cranking Amps are needed for the battery on a Styled 1951 JD B. the book says to use a heavy duty 15 plate battery but I could not find any information on cranking amps. I can pick up a 6 volt battery at Auto Zone with 560 CA but I don't know if that will work.
Thanks again....
Henry J
07-18-2005 11:39:58
 Re: Battery ? in reply to georgec, 07-18-2005 05:40:46
george
If you have a local battery supply specailist (like one that is a golf card dealer) I would suggest you call them for a comparison.
I got a higher amperage one from them at a reasonable cost and have been happy with it.
Those amps count when it is cold, unless you keep the tractor in the garage and your wife's caroutside lol.
dbwillia
07-18-2005 08:12:59
A fellow on the 8N ford site buys his batteries at John Deere, even for his pick-up. He recommends them for heavy duty use.
buickanddeere
07-18-2005 06:47:28
Run a new 00 ground cable down to one of the bolts that hold the starter on. That connection to the battery box is suspect at best due to years of rust all the way down to the starter. Napa is now carrying a line of AGM batteries.
John T
07-18-2005 06:41:43
George, I dont know how many "cranking amps" are needed to answer your question, but I can strongly recommend you install the heaviest and highest rated and most CCA you can buy that will physically fit into the battery compartment. Also use 00 Gauge battery n ground cables.
While a lighter or cheaper battery may start her fine in warm weather, when it gets real cold you need all the stored energy you can get which the heavier rated battery can supply.
John T
Mike M
07-18-2005 05:49:51
If everything is up to snuff it should work fine. I'm not so sure about that brand AZ ? Next time I buy a 6 volt battery I was thinking of trying an Optima brand. They cost twice as much but have heard good reports about them here. I have had some good service out of an AC Delco 6 volt and also good luck with an Interstate 6 and 12 volt tractor batteries ,but not interstates automotive series.
