1938 AR Gov, to carb rod length
Marty Z
07-17-2005 22:02:59
My AR runs too fast and I think that it might be the length of the Gov. to carb rod. It was broken off at the adjusting end and some one welded the broken parts together. I am unable to adjust. Does any one out there have a rod that they can measure so I can make a new one to the correct length. Even an over all length from center to center on a working tractor would help. I know it's a pain to measure with the gas tank brackets in the way. Thanks
Marty Z
F-I-T
07-18-2005 03:35:20
 Re: 1938 AR Gov, to carb rod length in reply to Marty Z, 07-17-2005 22:02:59
Marty:
You can measure that your self and work backward to the adjustment. It might take two people. Just open the throttle all the way, and hold the throttle plate open all the way on the carburetor. Measure between these two points, and that is the ideal length. Now you'll want to have the "elbow" on one end or the other ( I guess that would be the governor end) set at about mid-way on the threaded end so that it could be lengthened or shortened the same amount either way. That should be the length.
Frank
Marty Z
07-18-2005 06:36:17
 Re: 1938 AR Gov, to carb rod length in reply to F-I-T, 07-18-2005 03:35:20
Thanks to both of you. I understand what I need now. Just needed a different way of looking at it. You know what they say about 2 heads.
Thanks
Marty Z
Mike M
07-18-2005 05:27:03
Final adjustment is 1/2 a hole short of going in this assures full travel.
