60 Carb Choke Spring
Firebug329
07-16-2005 18:23:14
Can anyone inform on how to install the choke spring cover correctly. I have tried numerous ways and still cannot get together.
I can get it to catch, turn to install cover, then spring jumps off notch.
Also, what is the spring for?
Thanks
ChuckW
07-17-2005 06:05:11
 Re: 60 Carb Choke Spring in reply to Firebug329, 07-16-2005 18:23:14
the spring was to prevent flooding..as the tractor was cranked with the choke closed when starting it pulled the choke off....automatic choke, was used for years on autos, same principal. The spring is a little trick to install as it has to be preloaded...I can't explain it but could do it.
clay
07-16-2005 19:09:47
the spring closes it and the air going in the intake opens it
