4010 Gas gas hog
UncleTom
07-16-2005 17:52:51
Hello eveyone. A freind of mine has a 4010 jd that is thirsty on the gas consumption. I told him i would post something here as there is a lot of help here. He bought this 4010 and has the engine over haulded cause it was an oil burner. He complains that it is hard on gas and that he has to have the throttle open to about 1500 rpm to use it as it will foul the plugs.Black smoke too. I told him it is running rich. He agrees. He was going to have the acellerator pump pluged on it as some one told him that it might help but it was already done. Is this a common problem with these? Thanks in advance.
buickanddeere
07-18-2005 06:56:21
 Re: 4010 Gas gas hog in reply to UncleTom, 07-16-2005 17:52:51
The choke may appear open but the blade maybe partly closed. The engine temp has to be 195F to burn clean. As previously stated those oilbath aircleaners are noted for getting plugged anywhere between the intake stack and the carb. The mesh sometimes needs boiling out.
Tweak and tune the timing and mixture while on a dyno. This will find the lean carb setting without loosing too much power or suffering detonation.
Toss the origional plug wiring and use real solid core wire. I can't recall which plug size those 4010's require. Use an Autolite non resisitor 3116 or 216.
Mike M
07-19-2005 06:08:09
 Re: 4010 Gas gas hog in reply to buickanddeere, 07-18-2005 06:56:21
I would think the same plug as a 4020 I use autolite 388.
Mike M
07-18-2005 05:44:17
If your carb. is a square box looking thing made from aluminum it is a Marvel Schebler and should be replace with one made by Zenith or else it never will run right. I couldn't believe it myself when told this so I experimented and found it to be true.
donmyeil
07-17-2005 16:33:51
If you have the potmetal carb there is a diaphragm inside the rear cover that will get a hole in it and lets it suck gas straight thru. makes smoke and hard starting let alone excess gas consumption. if you shut the engine off too hot and it backfires you can just about bet the diaphragm is done. then put on electronic ign.
farmerboy77
07-17-2005 12:09:54
My father had a 4010 gas and we had the same problem. Engine and carb. overhauled by a JD dealer and everything. Timing set, complete tune up including a fuel transfer pump. The only way it would run is to mix lead additive to the gas and never let it idle for every long because it would load up and very hard on gas. The way the gas prices are today we ended up trading it off for another 4020 diesel.
Deere Farmall
07-17-2005 09:33:18
Check out the carburetor as mentioned. Be sure that you have the right coil. Those tractors use a 6 volt coil. There is a resister that lowers the voltage at the coil to 6 or 8 volts and a separate wire leading from the starter solenoid to the coil to use the full 12 volts when starting. If a 12 volt coil is used that has an internal resister, the tractor will run as you say. I have a gas 3020 and installed electronic ignition and the tractor runs much better with the electronic ignition.
mike brown
07-17-2005 07:57:59
Might be as simple as a sticking float valve. Chaeck all the usual suspects, cheapest first.
float valve
intake obstruction
needle valve settings
