JD # 7 backhoe bent cylinder
Ken Irwin
07-16-2005 15:25:22
Is anybody having problems bending the cyliders on their # 7 backhoes? When I curl the bucket, the cylinder for the dipperstick bends down. I have replaced the cylinder thinking it was weak but it still does the same. It always happens when the cylinder is fully ecxtended! The pressure of the hydraulis has been verified to be 1750-1800 PSI.
Timberoak
07-16-2005 18:53:05
 Re: JD # 7 backhoe bent cylinder in reply to Ken Irwin, 07-16-2005 15:25:22
When curling the bucket there is very high pressure built up on the dipperstick cylinder, there is a closed circuit relief valve in the valve bank to prevent this excessive pressure, I believe the part number of the valve is PT8126. This has nothing to do with system pressure and is only to protect the dipperstick cylinder when curling the bucket.Put a gauge in the extend hose of the dipperstick cylinder and curl the bucket in some hard ground, I believe this should not exceed 2000PSI, do not move the dipperstick control. While curling the bucket in hard ground you are trying to force the dipperstick cylinder in and this builds the high pressure, most likely the problem is in this relief valve.
Mike M
07-16-2005 17:30:49
Is it bowing it or is it actually putting in a permenant bend . Does the service or parts book show anything about a relief valve cartriage in some of the seperate backhoe valve bodies ? If they use them like the bigger hoes do yours may be malfuncting ?
