Hydraulic pump on 2020 vs 2030
Greg L
02-27-2004 17:46:55
Can anyone tell me if the 2030 has the same type of hydraulic pump as a 2020 mounted in front of the radiator? If not, is the 2030 pump as good, better, or worse?
jdemaris
02-27-2004 19:34:11
 Re: Hydraulic pump on 2020 vs 2030 in reply to Greg L, 02-27-2004 17:46:55
My memory may be a little foggy on the issue, but they both have front mounted closed-center piston-pumps. With some possible changes in fittings, pumps will be interchanable and might be the same. When ordering either of the tractors from Deere, there was a choice of hydrualic pumps, so it all depends how they were ordered. Here's where my memory lacks perfection - but generally speaking they were available three possible pumps - a small 8 piston pump (looks quite different from the others), and then the other two were the larger body pumps - all interchanable. One was a low-capacity and only had every other piston - so it was a four piston pump in an eight piston body. Next higher in capacity was an 8 piston pump.
