Do all JD 720's have a straight drawbar.?
BushogPapa
07-15-2005 20:20:28
This one has a straight drawbar with NO ofset..
All styled ones I have seen has had an offset to let you set the drawbar higher or lower...
Is this a standard drawbwr that came on the 720..??
Thanks....! Ron.
720Deere
07-18-2005 12:50:50
 Re: Do all JD 720's have a straight drawbar.? in reply to BushogPapa, 07-15-2005 20:20:28
The parts catalog does not distinguish the straight drawbar as optional, it lists the serial number break as the same old 57/58 model year break that applies to everything else. We have a '58 and it has the straight drawbar. The entire drawbar support is different to compensate for the extra thickness of the drawbar. I have the drawbar from I believe a 4010 in my '57 720. Where the support is worn at the rear it fits well, but is snug at the front. I believe that it is 1/8" thicker than the light duty 720 drawbar and it also has the bend or offset in it like my old drawbar.
BushogPapa
07-18-2005 12:58:40
 Re: Do all JD 720's have a straight drawbar.? in reply to 720Deere, 07-18-2005 12:50:50
I guess this could be a good thing, to have the heavy one, but I may have to adjust some hitches for it.. Maybe I can get a standard drawbar and shim it, from a 620 or something.. Ron..
Bimmer
07-16-2005 13:06:40
No, on the row crop tractors it was an option to get the heavy duty "straight" bar, why they didn't put a kink in the heavy duty one too is beyond me, possibly to thick for the tech. at the time. Anyway, the heavy drawbar comes in very handy for tractors that are still really worked, but normally the thin one lookes more classy, but to switch from one type to the other would require the drawbar mount to be switched under the tractor, four bolts i think, that isn't normally removed, and is probably well rusted and otherwise stuck to the tractor.
Doug in IL
07-16-2005 07:40:05
My 1958 720 rowcrop has a straight drawbar. It is a much heavier drawbar than the one on my 70 rowcrop which has the offset drawbar.
Carl NY
07-16-2005 03:54:21
The 720 tractors were available with a straight and offset drawbar. The straight drawbar was PN R20405R. The offset drawbar was PN R21333R. The hammerstrap was available for the straight drawbar.
buickanddeere
07-15-2005 20:50:14
Which chassis? Rowcrop, High crop, Standard or the Standard with the HD swinging draw bar?
BushogPapa
07-16-2005 02:27:40
 Re: Do all JD 720's have a straight drawbar.? in reply to buickanddeere, 07-15-2005 20:50:14
This is a Row Crop, narrow front.
This 720 has a Much heavier drawbar than my 630 maybe it is a Heavy Duty drawbar..??
Thanks for your help...!
Ron..
