730 D ES NOISE AND KNOCK
LSCUD
07-14-2005 19:29:27
I purchased a 1960 730D with ES, It has been stored inside a barn for approx. 15 yrs by a collector. I serviced and replaced all oils with factory specs. when I hooked tractor to bush hog, the pto works fine, but it makes a whining noise from inside trans right behind engine. Is this bad and should I look inside trans. and inspect. also when it is running, it knocks and is a about twice as loud when clutch is disengaged. the prev
owner told me that this might be a loose flywheel. any suggestions?
buickanddeereg
07-15-2005 14:58:30
 Re: 730 D ES NOISE AND KNOCK in reply to LSCUD, 07-14-2005 19:29:27
I hope the seller allowed about $1500.00 for parts and shipping to install a taperlock along with thrust washers, gaskets etc. If you are real lucky a grade eight bolt treatment maybe enough.
720Deere
07-15-2005 03:06:26
It could be a loose flywheel, or it could also be a worn clutch driver.
Kevin L.
07-14-2005 20:29:34
sounds like time to verify the endplay and tightness of the flywheel. maybe new bolts and retorque and even verify that one of the thrust washer is not broken.
