720 hrs
herman
07-14-2005 19:19:12
Is 3200 a lot of hrs on a jd 720 diesel?Runs ,all there but rough looking.Rear rims good .Tires no good.Just very used and old looking.Not well taken care of looking .Not total junk eather?Guy wants 2500 us. Tanks for any reply Herman
Blksmok
07-15-2005 06:20:59
 Re: 720 hrs in reply to herman, 07-14-2005 19:19:12
Herman...ignore the hour meter reading. Believe what you see with your eyes. The 2 cylinders diesels were usually worked pretty hard and you can spend lots of dollars quick. If you're buying it to use, 2500 dollars is a good starting point for negotiations. If you're looking for one to restore, look for one that is already done and spend 4500 to 5000 dollars. The one you're looking at will cost more than that to get it restored.
Mike M
07-15-2005 06:06:26
I wouldn't put much faith in that hour meter ! Make your decison based on something else.
Kevin L.
07-14-2005 20:45:22
too me it's what you want the tractor to do for you and what you are willing to put into it to get it to do that. Do your research in the parts require to overhaul the big motor and small motor if not electric start and you will probably find that you would have more money in the tractor than what you could sell it for even if you could purchase it for 1500. But once the 720D is reworked and you use it awhile it maybe hard to part with. would wonder how much blue smoke while cold and how long it continue after it warms up.
mike brown
07-15-2005 03:31:04
 Re: 720 hrs in reply to Kevin L., 07-14-2005 20:45:22
I have a 730 with 4000 hrs that runs great so I don't think 3200 is a lot of of time IF the hour meter has been working all it's life. If the tin is straight and mechanicaly works 2.5k is a steal. You can't lose at that price. Not sure about the whine. It's easy to look at the flywheel and see if it is rubbing on the cover. A taperlock will fix flywheel issues for less than a grand.
Sounds like a sure bet to me.
mike brown
07-15-2005 03:34:27
 Re: 720 hrs in reply to mike brown, 07-15-2005 03:31:04
Oops, no whine on your tractor. Thats good! It was the previous thread.
herman
07-15-2005 19:32:33
 Re: 720 hrs in reply to mike brown, 07-15-2005 03:34:27
THANKS EVERYONE HERMAN
