WHAT IS THE LENGTH OF A 4020 FRAME RAIL ????
4520 OWNER
02-27-2004 16:05:01
Was wondering how long the frame rails are on a 4020? Was thinking of putting 4020 frame rails (with a 4020 complete front end unit) on a 4520 so I could put a lighter front end on the tractor. Looking at the Parts books they look identical except for the bolt holes placement for the different front ends. I am wondering if there is a difference in length between the two frame rails and if so how much? Any information on this would be appreciated. Thanks
Why not just trade it for
02-29-2004 22:29:36
 Re: WHAT IS THE LENGTH OF A 4020 FRAME RAIL ???? in reply to 4520 OWNER, 02-27-2004 16:05:01
Seems more normal.
Brokenwrench
02-28-2004 04:57:57
You will need the frame rails,front casting,fuel tank,hydraulic lines,and possibly a radiator,just to do the swap, then you will have to address fitting up the tin which is different from a 4520 to 4020.
Mike w J
02-27-2004 17:28:23
I think the casting under the fuel tank is diffrent and I think the frame rails are bigger channel then on a 4020 if the casting under the fuel tank has to be changed then the fuel tank and hood might not fit I had a 4620 15 years ago and am almost sure the frame rails are bigger
