7210 hydraulic problem
Janet
07-14-2005 01:30:57
The hydraulic pump is pushing 1500 pounds all the time and not dropping back to 400 like it should when the pressure is not required. We can't find the problem. Any ideas?
Tom (Ks)
07-15-2005 18:57:27
 Re: 7210 hydraulic problem in reply to Janet , 07-14-2005 01:30:57
If you have checked the load sense valve,I wonder if you have a leak to sump somewhere. You might have to take it to a dealer to find the problem. After the tractor sets overnight and is cool, start it up and feel around on the valves and hoses for anything getting warm and go from there.
Janet
07-15-2005 19:29:52
 Re: 7210 hydraulic problem in reply to Tom (Ks), 07-15-2005 18:57:27
Thanks for the ideas. It's at the dealers now and they can't figure it out. So far, JD Company engineers are stumped as well. I'll suggest the leak to sump and see what they say. I'll let you know what the problem is when we find out.
Tom (Ks)
07-17-2005 12:36:43
 Re: 7210 hydraulic problem in reply to Janet , 07-15-2005 19:29:52
Another thing to check is the check valve (RE46648) in the main pump for leaking. That will keep the pump in stroke just a little. Your standby pressure could be high and hold steady until a heavier load is put on the system, then the load sense pressure would increase. Over the years, these pumps have caused very little trouble. One 8400 had the yoke piston break and destroy the main pressure hose.
twopop
07-14-2005 20:18:36
even tho i have not worked on a 7210,i believe they are still a closed system.all other model deeres have used the closed systems clear back to the 4010.the closed system is supposed to hold pressure at about 2200 psi,when the pressure drops to around 1700 psi the pump starts pumping to raise the pressure back to the 2200 psi.as far as i know the pressure is not supposed to drop to 400 psi
